링크 Utili 3D - INVENTOR
  • Thread starter Thread starter Ilario
Ilario
I have thought of a new part of the forum where to collect sites that provide specific resources and not for inventor, 알려진 덜 알려진, 하지만 여전히 3d. 아래 나는 링크를 나열합니다, 누군가가 다음 업데이트를 추가하려는 경우, 나는 당신이 좋아하는 것을 할 희망 :
- cad3d 포럼 전용 자원 디자이너 -
http://www.cad3d.it/forum1/forumdisplay.php?f=115
이름 *: 웹 리소스에 전념하는 새로운 포럼은 어떤 기계 유형의 보고서 또는 드로잉 일반적인 링크.
_____________________________________________________________________________________________________________________________________________
- 발명가 -
mfg 커뮤니티 2009----------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------http://contentwarehouse.part-solutions.com/partcommunity/portal/autodesk
이름 *: Autodesk 파트너 사이트 모델 3d 및 2d로 회사명으로 구분모델 번호:: autodesk house 형식의 엄격함한국어: 영어, 프랑스어, 독일어제품 설명: 무료 등록 후
http://inventor.cad.de/bibliothek/bibliothek.html (영어)
이름 *: 많은 자원과 색상, 환경, iparts, 물자, 등의 맞춤화와 발명가를위한 sapecification 라이브러리.모델 번호:: 기본 발명가한국어: 독일 단지 purtope제품 설명: 완전 무료
http://www.firstcadlibrary.com/ (영어)
이름 *: 많은 부분과 관심의 범주로 구분, 단순하지만 효과적인.모델 번호:: 주요 인터체인지 (igs, stp, sat) 및 발명가한국어: 한국어제품 설명: 완전 무료
http://www.cbliss.com/inventor/parts/index.htm (영어)
이름 *: 사용자 중 가장 잘 알려진 발명자 자원의 소스, 부품, 어셈블리, iparts, 코드, 질감, 재료, 색상 등모델 번호:: 발명가한국어: 한국어제품 설명: 완전 무료
http://www.kwikmcad.com/
이름 *: 일부 부품, 코드, 매크로, tnts 및 inventor의 예제가있는 사이트.모델 번호:: 발명가한국어: 한국어제품 설명: 완전 무료
http://www.sdotson.com/
이름 *: 다운로드 가능한 부품이있는 사이트, 매크로, 다양한 튜토리얼과 애니메이터가있는 섹션 (운동 애니메이션을위한 발명가 용 플러그인)모델 번호:: 발명가한국어: 한국어제품 설명: 완전 무료
http://blog.inventor-faq.de/
이름 *: 다양한 부품과 매우 잘 구조되고 흥미로운 튜토리얼을 가진 매우 흥미로운 사이트, 독일의 네오 esclosivamente. .모델 번호:: 발명가한국어: 독일제품 설명: 완전 무료
http://www.b2-design.biz./tuts.html#
이름 *: 어떤 모델,하지만 많은 매우 유용한 자습서 가장 요청 된 주요 기능 및 비디오 자습서에서 구성 된 설명하는 것이 더 어렵습니다. 놓치지 마세요.모델 번호:No. - 발명가를위한 튜토리얼한국어: 한국어제품 설명: 완전 무료
http://www.cadforum.cz/catalog_en/ (영어)
이름 *: 등록한 사용자에 의해 많은 모델과 범주로 나뉩니다. 직접 입력할 수 있습니다.모델 번호:: 인터체인지, Autocad, revit 및 기타한국어: 영어, 독일어, 체코제품 설명: 완전 무료
http://hjem.get2net.dk/opad/
이름 *: 디자인 환경과 "iproperties collection"의 색상 구성을 변경하기 위해 inventor "colour 계획 주최자"에 대한 두 가지 도구를 사용하여 테이블 수확에 자동 스케일을 가지고 유용한 기능을 포함하여 모델에 추가 사용자 정의 속성을 추가합니다.모델 번호:: n.a. - 발명가 당 플러그인한국어: 한국어제품 설명: 완전 무료
- 일반 -
http://www.ohyeahcad.com/catalog/webparts.php
이름 *: 많은 기계, 전기, 금형, 전자, 배관 및 더 많은 세부 사항, 카테고리 및 표준으로 나뉩니다.모델 번호:: 온갖 인터체인지 및 인벤터를 포함한 주요 소프트웨어의 많은 원주민한국어: 한국어제품 설명: 완전 무료
http://www.tracepartsonline.net/(4t2zctbfgpag3q45msy5nf45)/global/index.aspx
이름 *: 회사 및 구성 특정 코드를 생성하는 이름과 관심 범주로 나뉩니다.모델 번호:: 온갖 인터체인지 및 인벤터를 포함한 주요 소프트웨어의 많은 원주민한국어: 이탈리아, 기타제품 설명: 무료 등록 후
http://www.envision.net.au/support4.htm에 대한 자세한 정보
이름 *: 아니 모델,하지만 conpens에서 그래서 많은 tnts 발명가 및 dwf에 tnt와 전체 자동차 가족.모델 번호:: ₢ 킹한국어: 한국어제품 설명: 완전 무료
http://partsv4.web2cad.de/powerpartsonweb.ppow?gb
이름 *: 회사 및 구성 특정 코드를 생성하는 이름과 관심 범주로 나뉩니다.모델 번호:: 실제로 모든 옵션에서 다운로드 형식을 구성한국어: 한국어제품 설명: 완전 무료
http://www.solidcomponents.com/default.asp?nav=2&tab=1&sclanguagecode=353
이름 *: 회사의 웹 사이트에 직접 링크와 그 회사의 3D 세부 정보의 직접 다운로드로 분류 된 많은 회사와 사이트, 이해하기 쉬운. .모델 번호:: 회사에 따라한국어: 한국어제품 설명: 회사에 따라
http://www.3dcontentcentral.it/3dcontentcentral/default.aspx
이름 *: 아주 잘 구조화 된 사이트, 스트레스의 범주로 나뉘어 주요 회사와 그 섹터를 생산, 기업에 직접 문의 및 요청 견적 및 자신의 온라인 자료를 공유 할 수모델 번호:: 견고한 작품을 전문으로하지만, 모든 인터체인지 파일과 다른 플랫폼한국어: 이탈리아, 영어, 독일어, 기타 ... 제품 설명: 무료 등록 후
나는 그것을 떠나, 다른 것보다 더 나는 발명자 사용자를 위해 열렸다, 그러나 한쪽을 열고 나쁜 생각, 단지 내가 그것을 좋아한다. 그것은 집의 모델에 의해 필터링되기 때문에, 얼굴, 또는 다른 사람이 기계 또는 발명가로 돌아 가지 않는다, 그러나 나는 추가 :d
별도의 목록과 같습니다. ·
또한 같은 페이지에서 선을 잡아 분할?
내 계정
주요사업
ok, 곧 내가 몇 시간 (작업 후 밤) 나는 계획, 나는 또한 마음에서 또 다른 변경, 각 링크와 함께, 모체에서, 그것은 무료, 지불 또는 등록 후, 그래서 완료.
나는 첫 번째 게시물을 편집, 당신이 좋아하거나 약간의 개선을 할 경우 나를 알고.
제품정보 에 있다. 나는 당신이 3d에서 아무것도 다운로드 할 수없는 것처럼 링크를 걸었다.
나는 또한이 사이트가보고 .... 그냥 간단한 디렉터는 무료입니다 ... .http://www.3dcontentcentral.com/3dcontentcentral/
예, 그는보고 같은 캐드3d 내가 전에 넣어 링크, 나는 두 배를 만들 싶지 않을 것입니다, 그러나 그것은 훌륭한 사이트, 감사합니다.
나는 그것이 아주 잘 행하고 유용하기 때문에 일반에서 그것을 잃게됩니다, 그것이 파트너 dasssault 체계이기 때문에 일반적으로, 더 단단한 삽화를 위한 아무것도.
http://www.allaboutinventor.com/Autodesk 발명가 기사, 책, 뉴스, 자습서, 팁 및 트릭
₢ 킹
프론트 페이지에 추가하지 않으므로 훌륭하지 않습니다. 특히 흥미로운 것을 찾을 수 없습니다.
ache this,그것은 흥미로운,하지만 iparts 및 iassemblies에 대한 단일 자습서입니다, 나는 그것을 분류하는 방법을 모른다. ·
p.s.: offense는 의미하지 않습니다, 나의 의견은 광산, 그들은 불신이 아닙니다;)
