새로운 규칙
  • Thread starter Thread starter Exatem
Status
Not open for further replies.
Exatem
새로운 규칙
절차의 규칙 다운로드----------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------
이 기능을 사용하면 메시지의 삽입과 미리보기 기능을 용이하게 할 수 있습니다. 모든, 새롭고 오래된 사용자, 일련의 【특전】 포럼에 참여하기 위해 더 즐거운 :
1) 질문 - 사용자는 친절하게, 기능의 적당한 사용을 위해, 자주 묻는 질문에 대답 초대됩니다 (뚱 베어).
2) 질문 – 게시하기 전에 적절한 키로 검색하는 것이 좋습니다. 연구분야 (위 오른쪽 상단) 제목이 이미 처리되지 않은 경우. 여러 subforum에 게시된 요청은 moderators에 의해 삭제됩니다.
그것은 포럼에 첫 번째 접근의 시간에 자신을 제시하는 것이 좋습니다.
그것은 한 번 발견, 같은 문제를 찾을 수있는 사람들을 돕기 위해 채택 된 솔루션을보고.
2) 미소 - 포럼은 간단한 절차로 미소 (얼굴)을 사용할 수 있습니다. 그들의 대규모 존재가 빠른 연결 없이 사용자를 위해 다운로드하는 페이지를 heavier 만들 수 있기 때문에 그들을 학대하지 마십시오.
3) 이미지 - 당신은 단추를 사용하여 포럼에 이미지를 삽입 할 수 있습니다 회사연혁 (고급 응답 사용). 텍스트에 삽입 된 이미지는 첨부 파일로 변환됩니다.
4) 모더레이터 - 각 서브포움에는 하나 이상의 모더레이터가 있습니다. moderators는 메시지를 편집하거나 삭제할 수 있습니다. 그들은 나쁜 단어, insults, pornographic 물자, racist 문 및 다른 어떤 다른 사람을 삭제할 수 있는 경우에만 이렇게 할 것입니다. "flood" 메시지도 삭제됩니다 (많은 동일, 반복 된 메시지) 또는 완벽하게 쓸모.
다른 사용자들에게 insults의 경우, 뚱 베어 (아래 참조) 자동 될 것입니다. 불필요한 직업을 피하기 위해, 당신은 모더레이터에 의해 호출 될 수 있으며 금지를받을 수 있습니다.
moderators는 무료로 작업하고 무료로 작업을 종료합니다. 따라서 보상을 제공하지 않는 사용자를 초대합니다. 응답에 더 중대한 주의 또는 속도를 얻기 위하여. 이것은 비교, 모더레이터 및 많은 사용자, 열정에 의해 다양한 문제를 해결하는 데 도움이, lucro 당 비·
5) 섹션 - 포럼 분할, 편의를 위해, 에서 이름 *, 특정 주제의 시리즈가 있는 각. 메시지가 잘못된 섹션에 게시되면, moderators는 적절한 채널에 대한 토론을 이동 할 권리가 있습니다. 아직도 생각을 남길 것입니다. 이 경우 모더레이터는 메시지 및/또는 토론의 취소를 진행할 수 있으며 사용자가 금지할 수 있는 목적으로 불필요한 메시지를 삽입하기 위해 표현됩니다.
6) 자본 - 그것은 모든 것을 사용하여 쓰는 forbidden입니다 뚱 베어. 인터넷에는 외침과 동일하, 그래서 당신이 그들을 둘 수 있습니다.
7) 개인 메시지 - 포럼은 "개인 메시지", 개인의 다른 사용자에게 이야기하는 실제 내부 inbox를 지원합니다. 이 기능의 가용성을 주기 위해, 그것은 "public"채널에 한 사람에 주소된 게시물을 열지 않습니다. 각 사용자가 포럼에서 최대 50 개의 저장된 메시지가 있음을 기억하십시오. 50 메시지에 도달하면 더 이상 상자에 정리 할 때까지 다른 사람을받을 수 없습니다.
8) 위 - 메시지에 응답하는 연습은 목록의 상단으로 돌아갑니다 (참고!)는 고려되어야합니다 이름 *· 포럼은 채팅이 아닙니다. 답변을 얻기 위해 patience가 필요합니다.
9) 서명 - 서명에 이미지를 추가 할 수 없습니다. 당신은 경쟁 사이트가 아닌 자신의 링크를 삽입 할 수 있습니다 다운로드·
이것은 광고 매체로 포럼을 사용하도록 승인하지 않습니다. 홈 페이지의 광고에 대한 모든 요청은 관리자 (cad3d)와 직접 동의해야합니다.
포럼은 confrontation 및 토론의 장소는 시장이 아닙니다.
10) 제한 - 논의하기 위해 명시적으로 금지됩니다. 불법 문제 (특히 컴퓨터 해적에 강조) 및 불법 자료에 대한 링크 삽입, 어떤 성격의; 이 유형의 모든 메시지 즉시 제거됩니다 그리고 저자는 즉시 금지됩니다.
11) 스팸 - 스팸 (unwanted 광고)는 forbidden, 특히, 우리는 사이트 competing에 참고와 더불어, 반복합니다 다운로드·
12) avatar - 포럼을 사용하면 자신의 개인 아바타를 입력 할 수 있습니다 (포럼에 메시지를 전달하는 모든 이미지). 우리는 친절하게 개인의 아바타를 복사하지 않고, 합법적 인 " 소유자"의 이익을 가지고. 불필요한 토론을 피하기 위해 avatars는 종교적 및 정치적 상징뿐만 아니라 에로틱 / 포르노 자연의 사람들에게 금지됩니다.
13)를 위해 관련 기사 · 이름 * 자신의 게시물은 15 분, 그런 작업이 섹션의 모더레이터에서만 가능 (또는 부재에, supermoderator 또는 관리자에), 이는 동기를 노출하도록 요청됩니다.
이 간단한 규칙을 위반해야하는 사람은 포럼의 사용에서 만료 될 수 있습니다. 금지는 포럼에서 토론에 참여하는 것을 방지합니다. moderators는 케이스의 기간을 결정합니다. 포럼의 관리 그러나 규칙의 특히 심각한 침해의 경우 영구 금지를 할당 할 권리가 있습니다. 홍수 금지는 모더레이터의 경고에 의해 전진됩니다. 경고가 무시되면 금지는 자동으로 한 달입니다.
그것은 금지의 동기 / 감소를 요청하기 위해 포럼에 주제를 열려면 금지입니다. 어떤 토론은 대답없이 즉시 닫힙니다. 이 유형의 질문에 대한 개인 양식에 문의 (이메일, 포럼의 개인 메시지) 모더레이터.
또한 mailbox를 나타내는 것이 좋습니다. @ 편집을 피하기 위해 : 예를 들어 Poplar를 사용할 수 있습니다. 에 의해 pluto.it. 스팸을 피하기 위해이.
또한 모바일 번호를 나타내는 것이 좋습니다. 개인 정보는 개인 메시지 (pm)를 사용할 수 있습니다.
cad3d의 포럼. 그것은 우리가 우리의 독자에 사용할 수있는 무료 도구입니다, 그것을 구성 사용.
Status
