Regole del 포럼
  • Thread starter Thread starter gerod
Status
Not open for further replies.
gerod
나는 포럼의 규칙을 다시 가져옵니다.
그들을 주의 깊게 읽으십시오!
절차의 규칙 다운로드----------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------
이 기능을 사용하면 메시지의 삽입과 미리보기 기능을 용이하게 할 수 있습니다. 모든, 새롭고 오래된 사용자를위한, 포럼에 참여하기 위해 규칙의 세트 더 즐거운 :
1) 질문 - cad3d.it의 포럼의 기능에 관한 질문은 "웹 사이트와 관련된 문제". 그 채널에 쓰기 전에, 사용자는 자주 묻는 질문에 대한 답변을 읽는 초대 (faq ).
2) smilie - 포럼은 단순화 된 절차로 smilies (faces)를 사용할 수 있습니다. 그들의 대규모 존재가 빠른 연결 없이 사용자를 위해 다운로드하는 페이지를 heavier 만들 수 있기 때문에 그들을 학대하지 마십시오.
3) 이미지 - 당신은 포럼에 이미지를 삽입 할 수 있습니다. 사용자는 느린 연결으로, 그러나, 그들의 단면도에서 그 것을 기억하십시오 그들은 이미지의 전시를 끌 수 있습니다. 이 선택에 대해 선택하면 이미지 대신 링크가 표시됩니다.
4) 모더레이터 - 포럼은 모더레이터가있을 것입니다. moderators는 메시지를 편집하거나 삭제할 수 있습니다. 그들은 나쁜 단어, insults, pornographic 물자, racist 문, 쓸모 없는 직업 및 다른 어떤 다른 사람을 포함 하는 경우에만 이렇게 할 것입니다. "flood" 메시지도 삭제됩니다 (많은 동일, 반복 된 메시지) 또는 완벽하게 쓸모.
다른 사용자에게 insults의 경우, 금지 (아래 참조) 자동 될 것입니다. 불필요한 직업을 피하기 위해, 당신은 모더레이터에 의해 호출 될 수 있으며 금지를받습니다.
5) 섹션 - 포럼 분할, 편의를 위해, 섹션으로, 각 특정 주제의 수. 메시지가 잘못된 섹션에 게시되면, moderators는 적절한 채널에 대한 토론을 이동 할 권리가 있습니다. 아직도 생각을 남길 것입니다. 이 경우 모더레이터는 메시지 및/또는 토론의 취소를 진행할 수 있으며 사용자가 금지할 수 있는 목적으로 불필요한 메시지를 삽입하기 위해 표현됩니다.
6) 자본 - 모든 자본을 사용하여 작성하는 금지입니다. 인터넷은 외침에 동등합니다, 그래서 당신이 그들을 둘 수 있습니다.
7) 개인 메시지 - 포럼은 "개인 메시지", 개인의 다른 사용자에게 이야기하는 실제 내부 inbox를 지원합니다. 이 기능의 가용성을 주기 위해, 그것은 "public"채널에 한 사람에 주소된 게시물을 열지 않습니다. 각 사용자가 포럼에서 최대 50 개의 저장된 메시지가 있음을 기억하십시오. 50 메시지에 도달하면 더 이상 상자에 정리 할 때까지 다른 사람을받을 수 없습니다.
8) - 메시지에 응답하는 연습은 목록의 상단으로 돌아갑니다 (참고!)는 금지되어 있습니다. 포럼은 채팅이 아닙니다. 답변을 얻기 위해 patience가 필요합니다.
9) 서명 - 서명에 이미지를 추가 할 수 없습니다.
10) 제한 - 그것은 불법 문제에 대해 논의하기 위해 명시적으로 금지됩니다 (특히 컴퓨터 불법에 강조) 어떤 성격의 불법 물질에 대한 링크; 이 유형의 모든 메시지는 즉시 제거됩니다.
11) 스팸 - 스팸 (unwanted 광고)은 특히 cad3d.it의 사이트를 컴파일하는 참조 금지됩니다.
12) avatar - 포럼을 사용하면 자신의 개인 아바타를 입력 할 수 있습니다 (포럼에 메시지를 전달하는 모든 이미지). 우리는 친절하게 개인의 아바타를 복사하지 않고, 합법적 인 " 소유자"의 이익을 가지고. 그것은 정치 당사자의 상징을 호출하는 아바타를 사용 할 수 없습니다 또는 그들은 여전히 일부 정치 언급이있을 수 있습니다. 인정하지 않는 것에 대한 불필요한 토론을 피하기 위해이.
13) 포럼에서 처음으로 활용한 새로운 사용자의 프리젠 테이션 : 활동과 과거 경험의 요약 설명은 다른 사용자가 답변을 측정하는 데 충분합니다.
개인 데이터를 입력하지 마십시오, 이름과 성 또는 회사 이름을 콘, 또는 전화 번호 또는 주소.
이 간단한 규칙을 위반해야하는 사람은 포럼의 사용에서 만료 될 수 있습니다.
금지는 포럼에서 토론에 참여하는 것을 방지합니다. 첫 번째 시간 동안 일주일에 두 주, 두 번째, 세 번째 금지를위한 한 달과 같은 사용자에 의해 나중에. 포럼의 관리는 규칙의 특히 심각한 침해의 경우 영구 금지를 할당 할 권리가 있습니다. 홍수 금지는 모더레이터의 경고에 의해 전진됩니다. 경고가 무시되면 금지는 자동으로 한 달입니다.
그것은 금지의 동기 / 감소를 요청하기 위해 포럼에 주제를 열려면 금지입니다. 어떤 토론은 응답없이 즉시 닫힙니다. 이 유형의 질문에 대한 개인 양식에 문의 (이메일, 포럼의 개인 메시지) 모더레이터.
cad3d의 포럼. 그것은 우리가 우리의 독자에 사용할 수있는 무료 도구입니다, 그것을 구성 사용.
포럼에 당신을 참조하십시오!
cad3d.it - 팀
_ 한국어
Status
