[email protected]
Hi, I have a problem with the inventor cam I would like to do an indexed processing with the fourth axis and all smooth row I establish the x rotation axis and put it in the middle of the piece... I carry out the first processing... Then I do the other workmanship by establishing a new axis z .. the problem arises when I go to create the gcode with the postprocessor for mach3 with the fourth axis, that in passing from one workmanship to the other it leads to g28 home therefore on zero having no security z, which is disastrous because it goes to collide with the piece.
I have obvious to the problem by inserting in the gcode after the g28 a z45 command that brings me the z safely and everything goes smoothly, but possible you can not do from the cam and you have to change the gcode.
Please if someone knows a strategy please help me.
