3d master project
  • Thread starter Thread starter falonef
Progetto 3D Master: Applicabile presso la vostra azienda?
  • C'é potenziale ma non siamo ancora pronti ad affrontare la tematica
    Votes: 0 0.0%
  • Total voters
    5
  • Poll closed .
It is a shame to have seen this discussion only now. . .
the topic is very interesting and certainly puncture of ideas of interest.
I attach some documents that can help you understand the mbe theme (model based enterprise - this is the real name).http://model-based-enterprise.org/index.htmlfirst of all this is the link to the association mbe which is an authority in this regard.
the problem of the bee is never nbell'engineering... putting pmes in place of creating a table is all summed up a nice saving of time.
The only real problem is that, together with the pmi, the way of quotating would be radically changed... the "constructive" designs should obviously be eliminated... but do you think there is someone who builds a model based on a 2d design?
in the annotated models it is necessary to put only the quotas and the tolerances that will then be checked. . . all the rest should be made to aprtire from model 3d.
the problem comes downstream:
- manufacturing... is the mfg department able to directly use a mbe model? therefore, the cam tools are able to discern between a hole d(and a hole d8h7? one will be worked with nuna simple drilling... The other must be argued. it is necessary that the cams act independently.. .
and then we are now entering the additive manufacturing era... 2d? ? ?
- quality'. who controls the model has a great advantage from the adoption of the... no way... if a cmm is evolved and integrated with the cad, it can create in a semi-automatic way (style cam) the path of control going to make leverage of the pmi of the 3d mbe.
- suppliers... suppliers must equip themselves with tools that can easily read a model mbe. step is a way... we normally propose the jt. nx format is also able to read a jt format generated by another cad and transform the pmi directions into real pmi.
In general, however, what they say, suppliers work better on 3d data than 2d.
And then, let's just say... is also a question of natural selection: Don't you want to evolve? patience... change of supplier... a little like 30 years ago when you passed from the tecnigraph to the cad
- legal... as 2d drawings have legal value, you are able to store them with a ltdr logic (long term date retrieval). .. is something to evaluate... 2ds are turned into tiff or pdf for example... 3D? How can you be sure that in 30 years your noted 3d is legible?
- documentation... who does the product documentation is ready to receive the 3d instead of the 2d? often, without saying, the 3d are made (in fact, remade!). there are now very efficient documentation software (cortona 3d for example) that allow direct use of 3d... and if you do not want to go too far, jts can be placed directly in office files (word, powerpoint, excel, etc). therefore for these people the 3d mbe is manna from heaven.
- acquired... purchases must send around no more tables but 3d. Is there a problem? I don't think so.
other considerations.
- 3D consultation. It is normal that a 3d is used to discuss while developing the product. Of course a nice piece of paper is better... question: is it impossible to have a "2d" of a 3d mbe? No!! indeed... it is desirable. . Normally cads (at least nx...) can sharply print you a "2d" loot to use for discussions... I often carry the example of emails. emails replaced paper communications, right? who of us still uses fax, letters etc.? Nobody.
you print the email to bring it into a discussion? Yeah, it's easier to pop a piece of paper... And what do you do with the paper that you've been sloppy about after the meeting? How do you throw it in the trash? Right, it's just that time to discuss.
Well, like a 3d mbe... print the view model (and it is similar to a 2d) ... discuss it and then that "2d" as well as a printed email throw it away.
ability of designers. designers have to change their heads... together with the mbe you normally do a nice asme quotation course because we all have a little forgotten the quotation rules and tolerances. quotating asmes, then quotating only the size that will then be controlled by quality is a mandatory and natural way.
cultural change. from previous considerations it is clear that the great obstacle lies in the head of people who have to change culture. who of you has my age remembers the betting during passage 2d > 3d... here, the bee is this... a battle to get people to think differently.
mbe of components/assembly. when you start a project mbe (and I have already followed and completed 3... the first in 2008, when nx and teamcenter really did a hard work) the first thing to understand is whether you can delete the 2d completely or by stages.. .
2d of components
2d of groups
2d mounting
Where do you start? :cool: I think you can do everything at once if the company decides... but at least 2d assembly and groups can be done effortlessly.
Good job.. .
hi the_matrix thanks for your interesting intervention
now I go on holiday but when I return I resume the discussion and update with new information.
I can only anticipate that the business after submitting the results of the preset phase has agreed to make a poc (proof of concept).
So there's an interesting job waiting for me.
in your description I have reviewed almost all the highlights to which we will be compared.
can you also participate in the survey?
thanks 1000 and good holidays to all
I read at level six is written:http://model-based-enterprise.org/capability-level-6.htmlit also eliminates all use of 2d drawings even by exception.
3d models are the master
no drawings are allowed
but it comes to me then to think that they have to change before revolutionized programs, no more sketcher environment, abolish the sketcher environment, then those of ironcad always understood everything
Why, I don't think the cads were born with the sketch, or I'm wrong, but then I don't think I'm talking about 3d work environments.
2d of components
2d of groups
2d mounting
Good job.. .
The problem, too, is cultural. sometimes by all the "actors" business, sometimes only technicians.
I have seen companies that, while having computer equipment (cad, cae, cam) at the cutting edge, fail to give up the 2d printed on paper to make an assembly.
But then in the end, the "important" contracts are still on paper.
I have seen that in use they look for figures prof. ing. who know the cat's environment and pay them + 30 $/hour
30 $/hour is the price that some designers work in their own without employees.
because if you have an employee with 30$/hour you don't cover the costs, unless you use any contributions, in this case a couple of euros net of taxes could remain there.
then it must always be understood whether that money is net or gross of social security charges and taxes
I see only now,
I am of the idea that this is the future, 2d drawings are now surpassed. . .
but if I say this around they take me crazy....and then you continue to manage the 2d....it is the mentality that is missing especially in Italy lacks innovation the desire to change if you are an innovator you look for new roads you are put to gogna....of course not always; But if your boss doesn't agree, you're done. You're being ridiculed with arguments like we've always done so...
Go ahead and if it was a bad idea for patience...(ps I don't think)
Leonardo said:
the audacity enterprise that raises objections
and he was right.... only now we realized how much reason he was....
an addition;
solid works already has the 3d quotation package is called dimexpert; but I can't export Step 242 isn't even in the 2015 version how can you do it? Some ideas...
an addition;
You should post the question in the solidworks section and see if anyone can help you. Then we could do a trade test. Okay?
if no one has written it yet, report this site deals with the evaluation of softwares that use step ap 242http://www.ap242.org/web/asd-ssg/step-ap242-benchmark;jsessionid=1dc8a6c093681f321f2b37b29c84
the list of cad converter products selected for the benchmark n°1 are the following:
ptc - creo parametric 3.0 <=> ap 242,
dassault systèmes - catia v5 (sxt v5-6r2014) <=> ap 242,
coretechnologie - 3d_evolution nx vx <=> ap 242 (for composite catia converter),
datakit - crosscadware catia v5 <=> ap 242 and nx <=> ap242,
autodesk - inventor 2016 pro <= ap 242 (import only).
nota : siemens plm participation still pending.
basically siemens (and therefore teamcenter) go on jt, others (ds, ptc, autodesk) on step. However, it seems to me a detail in the development of the 3d master. Of course it has its important practical implications, but if the toshiba or samsung or the " x company" decide to "seat the cause of the 3d master" I don't think that the format of exchange with suppliers can be a problem straight. Don't you think?
could be that the fact of having already in the teamcenter home (and then the jt format) is an additional reason to avoid steps in other directions.
In fact, for example in the automotive sector, it seems to me that in the design of body shop 2d designs were not constructive for a long time. at the bottom are only the gauge references (or as they are called now) or the holes or areas to be checked. So, at least from this point of view, for that specific sector, 2d or 3d master, it really changes little.
step ap 242 should be the perfect interchange, I'm sure if we start to say it doesn't need anything because some German hasn't updated yet then we don't talk about it anymore
apart from the considerations on perfect formats or not.
Unfortunately it is the market that decides the best format .
You didn't understand what I wrote, obviously or maybe you have other intentions. I only said that, within the problem "we eliminate the 2d and we pass to the exclusive 3d with critical tolerances and quotas in 3d" the "dilemma" of which format to use for the exchange with suppliers is of no importance. and a company will not choose whether to switch to 3d master or not just because a format is supported or not.
