add together to the library?
Stigness
hi to everyone, I would need to know if it was possible to add a set to the solidworks library.
I explain better, drawing agricultural machines, I often find myself having to use some small assemblies as standard components, and using them as a library component I could save time.
I know that I could save the axieme as part, and import it, but in this case I would have problems in rendering phase (the visual rendering is not the same).
Do you have anything to suggest?
ciao @massivonweizen Thanks for the answer. on the thanks, you're right, unfortunately I realized I didn't come back in my previous post. thanks for your availability.
