ansys hook circular section
  • Thread starter Thread starter natered99
regarding the application of force you should get the same result. in any case to escape any doubt you can always enter a code string using the "command" button that allows you to enter the same apdl code in workbench.
once the command window is opened, you will need to select the nodes by using the "nsel" command and then apply the force by the "f" command.
