archicad - gestione livelli
Mamorr
Hello everyone,
I'm looking for some tips to manage archicad levels.
I'll explain better.
in the study where I work we have many design studies.
I'll give you an example.
where I work we have a dedicated study for the interior and works on autocad. we receive several furniture proposals per day. I amount the design with the casting command so the lines remain active and I can simply copy and paste the new organization on the plant.
between the other I tried to use the translator's settings but I can't change the name of the levels, in another study I added a suffix to all levels added for example:
mob-muri
Mob-wc
mob-kitchen etc etc
but now it doesn't work anymore...I think it's a problem of studies (some work on autocad other work with illustrator so they save files as vector image files. ...
the problem is that levels multiply me and periodically I have to clean the file and delete all the unused levels.
What about my method?
Is there a command to verify whether the level is completely empty or not?
If not if you can create a list with how many objects are present on each level?
I thank you and I congratulate you on the forum! In this universe of programs it is good to share our experiences, I hope to be useful too!
mc
attributes manager, "unused helimin".
even if it does not delete the glosses (they are not called levels) used in the default element settings.
