block images with iron command
Saru
Good morning to all, as I always tried to find a solution in other topics but I find nothing about it.
situation: I have to move a series of multi-directors to which images are flanked. I would normally use the iron command to reposition the text of the multidirector without losing the ref. to which this "point". instead they are forced to move everything together (multidir+image), losing ref. on the drawing, because the images climb! ! .
I wonder if there's no variable blocking the size of the images.. .
I hope I've been clear and someone can help me!
Good job to all! :cool:
use autocad 2015-2016
I don't know if the pictures have to move or stay where they are.
there are no variables to block the appearance of images, however
After you have selected the areas to be ironed, you can remove the images from the selection pressed the mausc button (shift) and reclicking on the edge of the image. or, before closing the object selection, type _r (remove) and select the images.
other methods: layer blocked for images... But I know you've already thought about it.
variable variable variable variable frame to set to 0, then variable frameselection to be set to 0.
in this way images cannot be moved and selected. If that's what you want.. .
good planneroad, frameselection had escaped me! sin only that with the iron does not work! Mysteries of mother autodesk.. .
I tested now, to me with the 2016 version the iron command has no effect with those two variables set to 0. images remain unselected.
I apologize for my absence! !
I really want the images to move with the text of the mutidirector, without climbing!
