catia v5 r21 deformed vision
  • Thread starter Thread starter Vittorio
Vittorio
I installed the version of catia v5 r21 sp2 and with surprise I see deformed (I attached the image)
the same version I installed it on the other station cad and did not give this inconvenience.
the two cad stations have the same graphics card, nvidia picture fx580 , and the same operating system win7 64 bit.
I have installed the card update drives, but no improvement.
ps. on the previous v5r20 version I did not have this problem.
Help! !
thanks to all
I don't have the r21 (I use the r20) but you tried to look in the caty options by increasing the video output of objects, maybe they also expanded with new settings that other versions didn't have and hence the difference.
cmq could be a problem even of video card, if you could install the version on a machine with the different card (magari + powerful) ........... .
hello and thanks for your interest.
I tried with the options, but I can't access because the images are also deformed (see image).
Unfortunately I do not have the possibility to try it with a different board and cmq the nvidia picture are certified by dassault systèmes.
It does not explain, in any case, because on the other station falls identical, this defect does not occur.
ps.
I would do without going to the next versions, unfortunately we work with aunts that use the recent versions and because of things you have to update yours too.
will be my type of work, but sincerely I have not found differences between the r17 and the successive r18 r19 and r20
Thank you all for reading me.
I installed the r21 spk1 to try if I had your problems and it doesn't happen to me
what you show me...... I have a fx5500 picture with 1gb of ram.
for me is a video card problem, you have no chance
with the company that provides you cautious to try on your machine a card +
"performer"? ? ? ?
in the options of the video card verify to have set the option for optimization for dassault system. Probably this setting you miss. you find it under the properties of the video card under voice 3d settings. Sorry about the approximation, but they don't love work, and I'm going to memory. Let me know.
Bye-bye
Yes, I had set that parameter (image allego), but no improvement
If you have any ideas, let me know
Hello and thank you
it is that parameter and it has been set correctly.
At this point I would say to copy the catenv of the other machine on the new one to see if you still have the same problem.
I remember that in the catenv you could set variables to avoid having deformed the imaging at the time of using notebooks.
probably on the new machine in the catenv is set this variable.
if you are looking for in the forum under infrastructure the catenv voice you should find something
Thank you, you remembered well and I solved the problem.
add these 2 folders to the file "c:\programdata\dassaultsystemes\catenv\catia.v5r21.b21.txt"
catwidthmmofscreen=330
catheightmmofscreen=206
hello and thanks for the interest
theoretically if you have a problem, you should reinstall the catsettings and the catenv.
of course the originals to be reused must be in ordnine otherwise the problem reappears.
Let's admit you have a problem and you have to repay the catsettings and catenv, how do you handle this?
How do you remember custom settings and variables?
in the catenv there is a variable that addresses the reading of catsetting. I made a copy of catsetting with all customizations including the new toolbar.in case of malfunction gate all catsetting that catia puts in a default folder. what I missed was a copy of the catenv.txt
What do these two icons need?(enclosed image)
to export, in a file, and import all settings?
is what we do: catsettings and catenv are copied from a server on the user's stain. all through a catia v5 startup application.
the user only has to click 2.3 buttons and the game is done.
you know with over 400 users in three languages in different regions was the only thing we could do.
regarding options:
the first restores the initial settings
the second saves the settings depending on the user settings.
It is practically what we do with the application at the time of starting cat v5 then outside and not in the session
regarding options:
Bye-bye
These procedures of yours confirm that mine are right.
We only have 3 cat licenses, do you recommend that I do your procedure every morning when I turn on PCs?
I don't have a server, it's 3 independent stations, but they share a computer with two directories sharing, one of the catsetting and one of the projects.
Could it be an idea to automatically launch a .bat file, which deletes the default directory, catsetting, on all three stations?
I recommend it because settings are sensitive files that influence the stability of the program. You should just find a solution for custom toolbars.
but the variable values from where you took them?
If you refer to the variables to adjust the deformation of the video, I found them in a discussion on cad3d.it
You know what? ,I thought toolbars were stored in catsetting, but it isn't.
how do you save custom toolbars?
good falonef... I did not remember + of the existence of these variables, I had tried them in 18 or 19 a few years ago ............. :smile:
in the catenv there is a variable for the path of the user profile. is where the user specifications are handled. It's that folder you have to handle in some way.
for this reason I asked you how you manage all, but just all the custom settings
In general, resetting the user environment by forced copy does not fall into best practices. The "administrative" concept of catsettings can be properly structured, in which some values are blocked as admin, while other options feature the user's personal way of working can be left to its full management (graphic layout settings and everything else) ....
