catia v5 r21 deformed vision
  • Thread starter Thread starter Vittorio
I am with the same problem as you:
w7 64bit
video card nvidia
same driver
but shot of scene
two stations with two different monitors! ! !
brand hp but different model
with the most recent one there are no problems and installing it in place of the oldest one the problem of the exiles instead of the circles disappear! ! !
I immediately asked a question to ds that confirms the problem and invites to set the variables in the catenv.
the problem is that we don't have the same monitors, so for each location the variable values would be different
I wait for concrete answers from ds.
attention deformation often comes with the contemporary use of two monitors
Good morning to the whole community cad3d,
I too, like the user "emme", are struggling with visual problems. a circle is oval (as from attached images).
the installed version is as follows: catia v5r20 sp7 (64bit).
I hope in a possible solution. Thank you.
ps. I tried to add the two strings, as suggested in the discussion, but without results.CATIA V5R20sp7.webpCATIA V5R20sp7(2).webp
ps. I tried to add the two strings, as suggested in the discussion, but without results.View attachment 39570View attachment 39571
I add that display is normal with a 1920x1080 monitor, things change using a monitor with 1280x1024 resolution.thanks to attention
You have my own problem, and I can't solve it. I tried monitor settings to change it but nothing always the set thing.... I have two monitors to work and it is in extended format will that be the problem?
the problem had been solved by ds on our explicit request with a hot fix semra on 05.
so starting from the cv5 r20 sp05 you should no longer find the problem
Staff online
