connect tolerances from 3d to drawing
emanuele grasso
I did the hole command and added tolerance.. Is there a drawing setting to automatically put the tolerance ø8h7 ?
you have to create the view with the other button, similar to what you used but slightly different.
If you don't find it, put the toolbar so I can help you
you must select the plan in 3d to indicate the orientation of the view and the projection of its quotas
But is there a way to make me count the holes that are plug, threaded or normal? I mean,
3 x 8h7
Can that 3 be automatic?
but there would be other solutions.
type create a parameter with 3 value
then use a matrix where you could lean on nr 3 for the amount of holes.
then create a text linked to parameter 3.
it could work
I don't understand.
or better I have understood but I cannot translate it into cad commands:(
If you want and time to show me, I'd be grateful. .
Is there also a setting to put the center lines of the holes and the axis lines in red?
I started catia as administrator by right-click "execute as administrator "..I went on the color of the center lines but it does not make me change :(
right at the top I see the standard hanging.
you should select the custom one in your design and then try to edit and save.
After that you have to update the design with the setup page menu
I think that the administrator leaving you did is not the casket, you just started the program as an administrator, because it doesn't make you change anything.... or am I wrong? ?
You're right. .
What do I do then?
must be configured files and casetting ....... is not that I don't want to help you, but now I can't, possibly in the afternoon
