connect tolerances from 3d to drawing
c:\program files\dassault systemes\b17\win_b64\code\bin\catstart.exe" -run "cnext.exe -admin" -env catia.v5r17.b17 -direnv "c:\documents and settings\all users\application data\dassaultsystemes\catenv" -nowindow
e' questa la stringa per farlo departe come amministratore ?
if... dove la scrivo per far vare catia?
it would seem ok...... .
you need to edit the enviroment file under the catenv folder
edit the file and set the variables:
catreferencesettingpath= (put position catsetting administrator)
catcollectionstandard= (put standard position)
Now I have no procedure...... I think it's all....... maybe someone remembers something different or to add.................. will intervene:
hit the link of the throw file cat and put that.............. If you're using 17 obviously
@mcbramby Sorry, but I need to understand in detail. .
I opened the only file found in catenv and is called "catia_plm_express.v5-6r2021.b31" (my license name) and "catreferencesettingpath=" I have to add "administrator" after that equal?
and then to the line "catcollectionstandard=" I have to add what?@vittori I put admin where you told me, I started casket and still does not make me change xml :
I think I still have to do the procedure that he told me. @mcbramby properly?
thanks for the help
I'll give you my lines as an example:
catreferencesettingpath=l:\catsetting_admin\catsetting_adminb29
catcollectionstandard=l:\mio_standards_catia
Let us know... .
The procedure is the one that wrote you @mcbramby combined with the "-admin" command of the post #27
I feel like you're in the high sea with catsetting
is not a simple thing to explain with messages
first you have to launch the enviroment editor program (right-click administrator)1652955551089.pngwill appear this window where you will protract to customize the address of your folders
1652956501587.pnggo out saving and then enter with - adminfrom now on all the changes you will make will be saved
regarding drawings
ps: @emanuele fat You've already been told more than once, but apparently you don't understand it and keep writing requests for help in a discussion whose title has nothing to do with what you're asking.
so doing we're not helping others with your own problem.
If you continue again, I personally, is the last time I help you.
simply when I asked a question about tolerances, I said "I also ask how to make the red center lines automatically" thinking it was a quick thing instead it is not so.. Surely the red axis lines have nothing to do with tolerances but are two arguments that make (both) part of the cat's drawing environment.@vittori It is not true that you are not helping other people with my own problem. . anyone can interact without any problem and without any kind of restriction.
It makes no sense to create a discussion that has a question and an answer and then dies there..
@emanuele fat Don't take it.
but, if a user enters the forum and searches for information on how to enter as administrator in the cat.. I doubt that the title of the debate "connect tolerances from 3d to drawing"
lo attragga
