Thank you. @gianni do not worry if you cannot do the last pdf, they are all similar components.Hi.
These are drawing, without 3d, so I made you pdf, one is jpg for the off-sheet part.
still missing 10771140 cop.ant. n allum. olmo 18-48 -small hub- (I can't do pdf, I have to do tests)
Thank you very kind!I converted it into .dwg and then I did the pdf
allega il fileGood morning I would have a problem with a caty file that once imported into inventor I only see it as a surface and not as a solid. Can anyone help me?
