Hi I would do so but I have wf4
I would try to add to the axieme the details with color to be copied
then in attributing the color choose from particular (the one with the particular color ) and associ
for last I delete the details with the color to be copied
If you leave the same name to the color it is likely that you do not hold it, you should create a color with an ad hoc name in the particular color to be copied that then will be recreated in the particular to which you will associate
I hope I've explained that.
read This is what and all the discussions linked within it. . .
I don't have time to replicate it again, but try: after saving the appearance in global.dmt, I think I remember that you should close the program and restart it. this because the variable global_appearance_file it needs to be loaded on startup (if I don't remember badly it should have the icon of a monitor to indicate this thing, instead of a saetta).I don't get it. I've uploaded a part of the file-propriety and set it in polyamide material. 6 then...
tools-options and opened the config.pro (with address c:\lavoricad.config.pro) and I recalled below to left the string global_appearance_file and in value I put global.dmt then I made strumnenti-management aspects-creates new appearance and I named it poliammide_6 , I closed and colored my seal. saved...out the side; erases not seen...loaded another seal and in file-propriety' I assigned it as polyamide_6 material but did not color me anything... Where did I go wrong? ?
I think this is the problem. after I created it, save it in the global, then close....I did not refer to the rescue of the part, but of the new aspect in the global, then I restarted the program, and try....then I made odour-management aspects-creates new appearance and appointed it poliammide_6 , I closed and I colored my seal. saved...out the side...... .
I attach my color file, you'll find some shades of white, if you don't get well you can update them easily.
greetings
