create table parts by ipart table
  • Thread starter Thread starter orangopotamo
orangopotamo
:confused: hello to all
I am using inventor suite 2010 64 bit
I wanted to know if someone can help me, I created an ipt file in which I entered an ipart table with various rows, the problem is that when I put the particular in the table and create the list parts I can not show all the rows present in the ipart table but I can only do it for a single line, I need to insert the rows present in the ipt file so that the supplier has the references of the various codes even if the design is one for all the details.
I ask you if someone has already had this problem and managed to solve it or I create the table manually but then in this case the ipart table "I don't need anything"
thanks for the help
hi, I don't remember in 2010, but both in 2011 and 2012 you can do.
use the table command and select the view you put on the table. in the window you can choose which parameters display in the table you enter.
