cut a 3d object by drawing a cutting line
  • Thread starter Thread starter andr34
andr34
in autocad how do you do (always you can) cut a solid 3d indicating in the active view a cutting line?. with rhinoceros is simple and intuitive, with command cut the object 3d to be cut, select a line and rhino will cut me considering a plan perpendicular to the view generated by the cutting line, very simple, but with autocad I did not understand if you can do, I tried with cheek but not succeeds me.
Thank you very much
ucs v trancia
Thanks gp!
is already a step forward, so if I have a straight in ucs v I can easily select the two points but if I have a little polylinea with zig zag pattern it is not possible to make him understand to cut with the orthogonal plan to the view generated by polylinea or spline?
ucs ogA ghetto traditionbut also look at these command options [oggetto piano/surface/assez/vis/xy/yz/zx/3Points]
Thanks again, I repeat to understand if I understand why I can't
-I'll buy a cylinder
- I put myself in front view, here I design a polyline or a spline that intersects the cylinder
-ucs object, select polylinea or spline
-draw/select the cylinder send/active object plane,seelect the polyline and send
but it does not cut me anything, the cylinder remains whole
thanks tristan then it is as I imagined, there is no way to cut a solid or surface from an orthogonal view by selecting only a cut line. I asked why with rhino I was so accustomed to doing it and I found it so comfortable that I didn't seem possible you could not even in autocad.
Thanks again
