andr34
in autocad how do you do (always you can) cut a solid 3d indicating in the active view a cutting line?. with rhinoceros is simple and intuitive, with command cut the object 3d to be cut, select a line and rhino will cut me considering a plan perpendicular to the view generated by the cutting line, very simple, but with autocad I did not understand if you can do, I tried with cheek but not succeeds me.
Thank you very much
Thank you very much
