default setting design view
  • Thread starter Thread starter Filo
Filo
I would like to change in the base tab -> drawing view default settings but I looked everywhere and can't find them.. . .
in the specific I would have always appeared "spigoli tangenti" and the style was "hidden line removed"
Thank you very much
thread
p.s. I think this question has already been asked several times, but unfortunately with the research I found nothing
open template template template, document-set settings-from the drop-down menu: shaded with edges. apply and save the template.
from now on each new file will be generated with the correct setting.
same thing applies to files already created, if you want to find the shaded view with edges, use the same command and the subsequent openings you will find it correctly. . .
alby says great.
if you don't want to create templates:
application/display/appearence options
set "application setting" > setting> visual style
Sorry I'm late. .
my problem not on the viewing part in 3d, but on the part in 2d, drawing mode, in fact I speak of "virtuous shapes" and "hidden lines" removed.
If I hadn't been clear enough I will try to attach screenshots
I take the 3d. in the design environment, I would like that in the display options, the check on " tangent shapes" and "filettatura" was always active. Is it possible? use inventor 2013 thanks
I would also like it with tangent lines always present, I have already tried on the template, but nothing to do...... .
tarkus confided in you.. then I am fried:frown:
If you trust me, stay cool...:hahahahah:
apart from the jokes, I couldn't.
the only way I found to set up is to insert a view and check out the tangent lines option.
but it makes no sense to have a template with a view already inserted. .
I open the thread because I was looking for another thing and I came across this, if it can serve I give my little contribution: as tarkus did is correct, you go into the template, you insert a random view of a 3d part and you check out tangent lines. it is ok, you delete the view and you save the template. should work.
and instead do not go (at least to me)
in fact I wrote:
"of the rest the only way I found to set up is to insert a view and check out the tangent lines option.
but it makes no sense to have a template with a view already inserted. . "
ie, as long as at least one view inserted the option tangent lines is sectable. without a view inserted, you can not give the ok to
Display options dialog box. ..so ciccia.
