of theories and methods to dimensional the bolted joints are to iosa, more or less scientific, more or less empirical.
and, incredibly, all come to similar results
then, we start from the weight to support.
130 kg, to be supported with 6 screws
are 21,6 kg each screw
as security, we say multiply it by 1.5 to consider the dynamic factor and 1.5 to consider the fact that they are hand-held
are therefore 21.6*1.5*1.5=48.6 kg each screw must support
it supports it by friction. the friction coefficient you defined it in 0.15. therefore, the axial load that must provide the screw will be equal to
48.6/0.15=324 kg
Now, you can make two real.
on the tables around the screws, find the tightening and precarious values for the screws
in the table that I use, a m6 in class 5.8 is tightened up to 6.8 nm and get a preload of 6.1 kn (622 kg). This leads you to say that the screw holds with an additional security factor of 1.9
the other verification is to say that the screw in class 5.8 has yield load of 500*0.8=400 n/mm2 (40.7 kg/mm2)
if I hold it to 80%, the tension with 40,7*0.8=32.56 kg/mm2
Since for a m6 large pitch the resistant section is 20 mm2, the axial load that generates the screw is equal to 651 kg (note that is gross similar to those 622 kg previously). as you have calculated that you need 324, even here you have an additional security factor of about 2
where is the "truck" for which you suggest to change vines?
simple... In the meantime a screw like this is a moment to ruin it while you're smiling, so your calculations of loads and precarious go to ladies
second consideration. . 130 kg are "little" and the influence of external factors is felt. between the serious and the facto, if one leans on the picture immediately adds another 50 kg. and if you think that from that painting we have to get out of the electrical cables (which weigh... and so much!) you will understand that the true safety is down!
However, I repeat the concept, you are in a beautiful dilemma.
What do you mean "you can't change, the situation is like this." ?
If the calculation said "don't hold", what would you have done? kept so why can't you change?
the calculation now tells you "rules, but it is not as safe as the experience suggests"
So once again... .
or deny yourself (of the series you tell the customer "better to use the screws m8 class 8.8) but you are sure to sleep at night
or confirm the vines and experience that on that painting never make the nest a buzzard, otherwise it risks coming down with all the nest and the eggs
