andreaxg1
hi, I press that I use autocad 2007 in 3d with basic notions because it helps me with the structures we build, being we a construction company. I have recently passed from autocad 2002 to 2007 and I am faced with a problem that I will try to explain well and synthetically:
when, in 3d, I use the command line or polylinea or other drawing commands or I want to change the ucs the pointer, passing on the design whatever the view, it seems that automatically selects the faces of the solids that it meets and if I also can click the point from which I want to start a line or anything else the program in the meantime moves me the ucs I do not know with what criterion, and then it excludes snap to other points that interest me.
I therefore ask you if there are any parameters of the program that I can change to avoid these problems.
Thank you very much.
