draftsight on mac and file openings from finder: it does not work.
gerod
Good morning, everyone. I press that I also tried in the draftsight forum but I did not find answer to the question (others have this problem).
I work with the mac and I bought the standard ds license (every so I have to put hand at some files). until some time ago, when you could use the free or beta version, double click on .dwg files from finder and open the files. since I upgraded to the paid version, if I open the .dwg file opens ds but an empty file appears to me (noname.dwg). to open the files I have to go on the "open" menu of the program and look for the file. so it works.
I tried to clean the settings but nothing. only remains the clean installation removing everything I have on the mac and traceable to ds.
Did someone have the same problem and maybe he solved it?
currently working on mbp15 and blue sur (last updated version but the problem was the same on cathaline).
Thank you!
Three or four years ago, it happened to me with the free version, since then I haven't used it anymore.
I attributed the problem to the fact that the software was little native to mac, among other things also edrawings at the double click showed an empty window, then resize the same window appeared drawing.
