prosteffe
Good morning to all,
work with autocad civil 3d 2017 and I came across a problem:
inside my card I have two layers, one in which there are the points with coordinate z = 0 but coordinated x and y correct, and a second layer containing text labels that express the quota (z) with x coordinates and y "balanced" (they would know the coordinates of the label); in practice with both active layers you see the point drawn in the correct planimetric position and at its side there is the label describing the point quota. I would need to export the points like x, y, z, associating with the x and y positions of the point, the quota expressed in the label. the points are so many so I'm looking for a solution to manage all the points together, although I don't know if it will be possible. I tried with extinction and I can extract the points like x,y,0 and the labels like x,y,0 with the quota expressed in the column "value" (only for labels) but to associate the quota to the point there is to be mad as the x and y coordinates are different.
I hope I've been clear and I thank you in advance who will be able to devote time to my problem.
