edge flange after converts to sheet metal
  • Thread starter Thread starter reggio
But here I'm not here yet...
Where's the trick? ? ?
... I attach my proof to which the bending does not add.. .
... in the other I also tried to cut off the slice but it does not work and in fact cutting as I show it should not work because it alters the thickness sheet ... :confused:
... explain to me ... with simple words and an example file if possible... :36_1_31:
Reggio,
the cut you have to do normalWith the sheet always reminds him to flag the option.
then, as mike said, the solid converts often gives problems (unexplained...). you can do it in the same way using the "old" feature of insert folds and so generally works and you don't even need the normal cut anymore (there's the extra pass that you must first empty.. but you did the same.
greetings
Marco:smile:
...and so that sampom, tired of the continuous grunts, laments and frogs coming from modena decided to give him the decisive stroke of grace making me see all this from another angle. . .
Reggio, the cut you have to do normal!
(there is the extra passage that you must first empty.. but you did the same.
... I did it only because I was copying the method used to carcate to understand the ark.. .
..cut "normal":
normal normal normal
Reggio: Check out that normal option christmas in cutting function!! ! ! ! !... ah... here's what the hell is that command:redface:
However I attach another solution of the reggio sheet.
...continuous with the dish of the amber: I only looked at your solution now,
First it seems complicated, then... then I didn't happen ... I erased some steps (after cut-extrusion1 onwards) that I can't repeat... I miss the commands... :36_1_4:
If, when you have a moment, I would like to make a video or 4/5 screen shoot of the last steps, I would be grateful. .
Well... Thank you all, I'm going... to hide me:
. . . as not said "impossible to make a normal cut..." but vaaaaa.. .
I make a solid fold and I send in production, then we'll think about it... :frown:
publishes the file the same, I do not understand the problem.
Have you tried to remove the "normal"?
if it is perpendicular to the thickness of the sheet does not need and perhaps breaks the bales.
Hi, the problem is always that... :
tyrannical hopper made with loft+converts in sheet metal does not accept flange of the edge (in place of extrusion-fold below) nor with extruded/normal cut. . :confused:
... allegiance
satisfied with how I did... I'm in a hurry.
ps, but are you sure that the bending machine can bend that hopper?? ?
I think he'll put it on the tip and cut it in two by bending two profiles to u.
ps: I put a note in a quota, it is wrong, I did not update it... but it's just to make you understand the reasoning
that I did to set that measure.
I already told you,
instead of solid converts usa insert folds that always works (almost:biggrin:):
TRAMOGGIA TRAPEZIA.webp - View attachment TRAMOGGIA Reggio.rar (but the functions and options all control them well.. once at least, come on.
. to tell the truth I haven't opened your last file yet, this is the first you posted and maybe now your problem is another.
However, to avoid errors you could try to do it all directly with sheet functions, without switching from the conversion/evacuation of the solid.. with that form you can still easily.
greetings
Marco:smile:
In my opinion:
I don't know the equipment you've got, but that's pretty "dark." from us in the workshop I could not do it (no however to "closed ring" with only one welding).
I just looked at your last file............ .
And I had done one of them cutting n or r m a l! !
I'd give you a butt in my head.:biggrin:
then, in the solid convert avoid making the cut on the same face you chose to keep fixed... But try to think about it before you do things.
:smile:
Wow. When you want and time, do you give us a little example for every guy?
would be more a damage than a gain, especially regarding the top down. If you can control it gives you great satisfaction and competitiveness that with the bottom up modeling you can not even imagine, but if you don't know what you do you lose control and combine colossal disasters.
It's not enough for a few tips and it's not enough for a targeted training day. it would serve more some project in addition so that you can learn the method without combining disasters.
remains the fact that for your products could be better a traditional approach so you have the freedom to replace and components without worrying about anything.
... pure sembrar potrebbe philosophy, but just mount a set with more than 5 pieces to review your ideas... I'm getting more and more aware that I know nothing... :frown:
It happens to everyone, even to me when I see something I have always ignored despite the 12 years of intensive use! this must be a stimulus to grow (technically) and apply with maximum commitment.:finger:
for the file... Can't you download it again?
Reggio, save all the discussion as a web page, or print it and tien it at hand, in the reminder drawer to understand.
Unfortunately, functions that are not used often become not automatic at all times to be performed and is involved in forgetfulness and omisssiomas.
quoto l' amico sampom :-)
...I'm sure I've posted this question qlc now, but I don't find it so I repeat myself... :confused:hi, I made a log trapeze that I then converted into sheet metal,
Now I would like to add a flange of the edge to the base but swx does not allow me. . .
I also tried to cut to "pareggia" the sheet but it is not served:
do you use a make-up or how do you do it?
the sheet metal environment is different from the others because there is a necessary component to give the results that are expected and that is to know the principles on which the sheet is based which are basically two : constant thickness and normal faces on the thickness.
when you come out of these two principles, it may seem to be still in sheet metal (conversion from solid to sheet), but you are no longer.
this to tell you that I prefer the design of sheet metal parts using the commands present in the relevant toolbar and not a solid design and then conversion.
the conversion commands in sheet metal have been introduced for imported objects without bending rays or for sheets imported from other cad.
therefore of the three examples you have attached, the last is the right path.
