MauroTC
a question from ignorant almost total on electric motors.
a motor that should be “transported” in rotation, indefinitely, does it damage somehow?
I better explain: I found an application where two engines were designed to operate a gearbox that moves the chain of a roller conveyor; a motor is reserve to the other and when one (a) should jump, it is automatically disintegrated from the system by means of an electromagnetic coupling and part of the other motor (b). the reserve motor (b) in practice always frees, through tooth belt to the main motor axis, and is then dragged natural life during. theoretically if the first one doesn't jump could stand there running empty for years.
we should replicate the application and before we invent something better, change system, put a second graft, etc. I wanted to understand if instead you can consider that a lawful operation. . .
Thank you!
Thank you!
