enormous deformity
  • Thread starter Thread starter gtsolid
gtsolid
ciao a tutti,Cattura.webpin this model, in that particular area, I have an absolutely huge deformation.
I checked the material, the existence and the congruence of the constraints, the contacts between the various parts and everything seems to me in order.
What is the problem with you?
but how is deformed?
is that deformed, I tried also isolating the body (via roller, engines, etc....)
the solid of the body is composed of a multitude of bodies, to which I also tried to merge them through the function "abbina", but nothing
apart from that mesh is not tolerable (and already this can bring errors of convergence and approximation of the result ) but then it is not possible that the minimum shift is 34 mm if the system is at least isstatic!!!!! there is a clear error in the constraints, the global ones and most likely the local ones (between one component and the other) that in ansys are always a beautiful bitch.
to make us understand better you should show us the display of loads and constraints.
in any case improves mesh and resell constraints.
I mean see how it deforms to the original. however the minimum will be 0, not 34 mm
I found 2 errors:
- some characteristics of the material (granite) had not been transposed: they had the bar above the name of the property
- a component wasn't digested, it seems there was some game.
This last point has not been resolved: It seems that at least another element is not properly bound. I guess he's suspended in half the air. Is there a way to understand it from ansys? or piece per piece (they are hundreds) do I have to see them from solidworks?
If you're doing a multibody analysis is one thing. but I ask myself, why don't you use solidworks with its beautiful static symulation module, do mesh not congruent and see what comes out? clearly you have to simplify that thing there because if you have to study the frame you have to remove everything else.
What do you mean you didn't digest?
with solidworks there can be interference, too complex geometries compared to mesh and similar things.
It also happens with solidworks, if you have a carpentry as a multibody part and the plates do not touch and apply loads you will see the plates flying in a destroyed way. so many times it is necessary to retouch the model only for the fem by adding a physical welding (maybe an extrusion) or change the contact geometry and cutting of the sheets.
how does a body stay in half air?
try to see the deformed with high scale factor and you will see where the untied body is
typically the precision of the solution increases to the decrease of the element size. below a certain threshold, the solution converges to an asymptote and continue to decrease the size becomes useless. These are basic things. a mesh so wide, even a single element on the wall affected by the analysis, is not appropriate, especially if you expect bending phenomena.
Is there a way to show the deformed of what was calculated until then? I can't find the body not in contact
What version of ansys use?
you can see results with scale factor. then you can also see the original solid in transparency, even in wireframe.
try first to make a calculation by entering a convergence criterion!
I use r16.
I have no access to the deformed (and therefore to the convergence criteria) because currently I have the error 1532164008702.webpfrom here I assume that, being the mesh already dense, there must be something not properly bound, that I cannot find.
it would be nice to know what knot/element was found this excessive deformed, and to what body belongs
Yeah, it's the best thing. Thank you all!
by curiosity: how do you model the bearings? do you have best practices in this regard?
therefore create revolutions on the model only. I would like to thank the rapporteur for his excellent report.
for a fem the bearings do not model. use hinge or cart constraints, 3d constraints, bearing bond if you use solidworks symulation.
I think you're setting your model wrong. If you claim to make a fem with a frame with mounted a roller with or bearings and other mechanics I would say you have already mistaken thought.
Only one mechanical element at a time should be studied unless the elements are similar and homogeneous.
