error osm 0014
  • Thread starter Thread starter marcofa
marcofa
during rescue of assemblies often appears error osm 0014 unwritten writing, internal error.
Does anyone know what the cause might be?
Mar
cleaned with catdua, but the problem persists, twice does not save and once you, maybe depends on how caia woke up!
hard disks are 3 from a tera raid 5: after check there are only 80 parity errors that on 3 tera seem to me an inetia.
Mar
take half the assembly in the logical tree -> delete it -> and save with no name.
see if everything goes smoothly.
If you then take the test again with the other half... until you isolate the problem.
there must be a corrupt file that creates problems....
... and if you find half, you still split it in half and reiterate the test:)
I would still try to save on other support.
the problem is equal on any file I have. I tried with a different project and the problem is the same, so it is not a corrupt file.
once he saves and another no second as he turns.
or try to save on a USB stick
if the problem remains I would reinstall completely cv5
Mar
Has anyone been able to solve this problem?
I happen to almost all rescues
on almost all saves seems strange, maybe wrong something in the management procedures save, read permissions write etc.
in addition to the above.. .
possible intervention of an antivurus that intervenes badly
networking where other users open the same file
file opening moved and resumed from folders without using appropriate saving management
try to turn off antivirus
and send (new folder) the complete product that from error
after you close caia and reopen
when you are insured with rescue management only operate in the new folder
