greenhouse in solidworks
In fact, not knowing what to put in, we do not know what the best way is. just your reasoning for the incumbents in height, but I repeat , if for example it must insert that there are 80 cm tall florists or flower tables for display typical of the greenhouses, or maybe see and divide the zone of trampling from that of plantation does not need the vertical encumbrance.
and if the client comes the brilliant idea to ask him some perspective view of the complete system?
Let's go up... I understand if a user who has autocadlt responded to him "comprati swx (if, create or whatever you like)" but they already have a cad 3d and already have the machinery made in 3d so: Why go looking for potential and not improbable roams like the ones I hypothesized here?
Hello, everyone.
I managed to make 3d of the base camp of the greenhouses, which then I have to replicate with the linear repetition.
I did everything with the welding function and 3d sketch (I didn't find much difficulty), but once I got to the function to be repeated to insert in the linear repetition it doesn't make me select anything. .
Can anyone help me?
Angel.
Hello, everyone.
If you use welded elements you are doing a multibody part so you can't repeat a function, you have to repeat the body. check in the command options and you will see that there is the field to activate to select the bodies and then it works for sure.
if however the goat is complex iho must select a lot of stuff. Do first work together and make the single roe series from there.
Everything solved. I used the repetition function by repeating the bodies.
thanks for the support.
Have a good day.
Angel.
he has specified plants and machinery.
It can also be that having plants needs to size the irrigation system (first thing that jumped in mind :smile:) to serve the heights. . .
However, you're right "not knowing what to put in, we don't know what the best way is. ":finger:
