import file pdf
Rossanaross
I have a pdf plan that I would like to import on autocad: I opened it with illustrator and saved in dwg, but when I open the file with
autocad the program sees me as a block, so I can't select single lines unless you open the block editor!
Does it happen to you, too? how do you want to use pdf file with autocad?
Thank you, reddish
if you use autocad 2017 vectorize directly from there without going to
...and anyway I'm accusing the question of boulders...
I did it but exploding it I lose the polylines that I need to extrude the blocks, also does not work the 'select similar' command that I would need to group the elements into separate layers.
there are several compatibility issues, it is probably time to move to 2017 as tristan suggests below.
Thank you!
- - - updated - - - -I'll see to it then! Thank you.
I did it, but exploded, I lose polylinese.
In the sense that the block contains polylines, so if you change it, you can find them, but when you explode the polylines too?
the genres the explosives work a level or group of entities at a time, but it could be to set up some variables that now escape me
