import .sldprt files into gambit
  • Thread starter Thread starter Jonny123
Jonny123
I would have a problem....I would have to import from solidworks2009 a file with the extension in object in gambit 2.3.16 to create us on a mesh...how to do?
I tried importing with acis but nothing.. .
design is an aircraft profile. ..a wing in substance.. .
Thank you very much! !
So...I tried to save from solidworks the file in acis format...and it doesn't let me save it with that format!
I tried to save him in iges and when I tried to import him into gambit, he gave me this message. .
What do I do?
error: translation requires license feature geom-trans
Can't anyone help me?
I'll explain. ..I had to import into gambit to make it mesh, the design of an aeronautical profile, a wing, created with solidworks2009....for the moment I managed only to save from sw09 in .igs and import it into gambit...the problem is that this type of file is 2d...in fact in gambit I find the sections of the profile and the line of the contour of the wing.
How can I import the design in 3d?
following other forums, it was recommended to save from sw09 in acis...but my sw does not make me do it with the following message: creation of unsuccessful surface, also gives me the path to see a .err file type
moreover gambit mi from this message:"error: translation requires license feature geom-trans"
This message comes out when I try to import this sw file...where can I take this license?
please help me if you can
