inserting materials into the autocad library
but you have to send the file open? Can't you send it in bmp, with the renderign already displayed? or in pdf?
about your question, instead yes, I had happened with a press center with which I also had problems with fonts!! and the only way to overcome the empasse was to attach to dwg, textures, and in my case also fonts!
....I carried out the procedure of the path, I sent my project via email and arrived without the textures....
if you want to export all of a design there is the command etransmitexport to a single compressed file all related dependent files related to drawing.
I also tried with this procedure typing from keyboard etransmit and saw that it exported me to a single compressed file all its dependent files related to the design but the project always arrived without the textures.
Thank you all, in the end I solved so: I created a folder, I copied everything inside (dwg + texture) then I zipped with winrar. the error was initially determined by the fact that I only zipped the dwg file, instead, I should have zipped the entire folder (dwg + texture).
