MassiVonWeizen
Sorry.
the rincogli...mento is powerful in me
It is correct that this happens. If by a solid do a delete do these, rightly can not be a solid anymore. because if you eliminate the face below and sideways you find material, even infinitesimal, you would have died.what I don't understand is that surface function (surface-extrusion3) where it erased the original face and solid became surface
Hi massive excuses I explained badly... I tried and since if you delete everything becomes surface.It is correct that this happens. If by a solid do a delete do these, rightly can not be a solid anymore. because if you eliminate the face below and sideways you find material, even infinitesimal, you would have died.
make a test yourself; create a solid and then do the command insertion putting the first option Cancel (without patch or fill to understand) and you will see that from solid becomes surface
