missing columns in design manager
  • Thread starter Thread starter michisub
michisub
I don't know what happened, but in design manager I have disappeared some important columns (and those fixed, uncheckable), such as "current path" and "new file name". . .
It seems absurd, I have no idea how to make her reappear. I also used the computer method (I wait and turn on the pc :p), but it didn't work!
If I click with the sx "columns..." those columns are not clickable, then they should always be there, but there are no!
help.. .
is it not that for some reason they have width 0?
try resize the columns present and see if they appear.
No, they have normal width. I have already tried to click size, fit, move up and down, etc, but nothing... It's crazy! Who knows what I've done to make her disappear, not even a computer illiterate, I've been using pcs for 30 years...
you can delete the registry portion related to solid edge in:
hkey_current_user\software\unigraphics solutions\solid edge\
In fact it is like making a reset of all settings; Only those related to design managers should be searched inside and eliminated to make them regenerated as first installation.
good morning to all, I also have the same problem, the only difference is that I do not have the registry key: hkey_current_user\software\unigraphics solutions\solid edge\
probably because I have the version of solid edge 2021
already from 2019 in place of "unigraphics solutions" there is "siemens" so you have to search:
hkey_current_user\software\siemens\solid edge\
