offset constraints in a volume
  • Thread starter Thread starter Real74
Real74
I ask if there is a licence that contains the possibility of binding a point within the volume of a solid.
alternatively, a "elastic" offset, i.e. a link between two points where the position is tolerated up to a maximum distance (it would be a "up to..." offset).
I didn't understand your questions well.
If you explain better with examples maybe we can help you
For example, I need to create a bond for a metal spacer, integrated into a rubber-metal bushing:
I can schematize its possible movements with a segment contained in a cylinder: the segment can move and rotate within the volume limits of a cylinder; so I could reproduce its limits of both axial and tilt yield.
another example, perhaps easier:
I must bind a point within a sphere;
with the licenses in my possession I only have the coincidence, which binds it to the center of the sphere, or the offset (with r sphere value) that would always force it to travel on its surface.
to me instead you need a constraint that allows to this point to navigate inside the sphere, then have a offset value from the ball center from 0 to r.
I know it's pretty slender as required, I apologize!
for the first uses in the same catpart two different bodies.
for the second uses the axis system in the center. from here you can bind the point.
ps: I'm not sure I understand you.
if so, post pictures, sketches etc. separately
