falonef
a little old the r24I only checked with the old version r24-.
you probably need to check something in personalizations from management, but I don't know where to put hands for this
already...decisously...but I keep hoping they give me the upgrade to the r30a little old the r24
grantee ...!!! ...already...decisously...but I keep hoping they give me the upgrade to the r30
I'm sorry if I make myself feel lonely nowit works
if you do a tilted catpart and click on the face indicated by the red arrow ... the view in the catdrawing becomes orthogonal to the face you selected for the table setting
However the right job is not that, but that of having a proper axe system
this could be a method to speed up the temporary solution
View attachment 65406View attachment 65407That post @emanuele fat I feel like a plant of a shed
also works with catproduct, already experiencedI'm sorry if I make myself feel lonely now
However you are right victorious.. this applies to catpart but not for product
because probably the plan with the blue sign, is not a plan but a surface does not plan.I also want to quote the hole of the suction cup keeping me parallel to the plane of the latter (to tell us where I made the blue sign)
with the front view command doesn't make me the parallel view on the suction cup plane while clicking on the same floor, why?
If it's not a problem, send me the stepnono is a plane subtracted by a solid in fact has a very precise diameter
I confirm, the catdrawings behave indifferently between piece and together. . .also works with catproduct, already experienced
In my opinion, the surface is not a plan.with the front view command doesn't make me the parallel view on the suction cup plane while clicking on the same floor, why?
no, however, all products are oriented correctly. . I don't know.the step does not change the orientation, I think you have not aligned well as recommended @alessandroc.
Are you sure you've locked the auxiliary part that you used to orient the axieme right away?no, however, all products are oriented correctly. . I don't know.
