pdf vector print problem
  • Thread starter Thread starter Mario.Rossi_
Mario.Rossi_
Good morning
I have a problem. I've never happened so far, it's been two days since my cad has and I don't know why.
practically printing in dwg to pdf a sheet all carriers come to me raster (pixellati). the problem is not the resolution because I always kept that default autocad (normal, 100 dpi) and never gave me problems, but I still increased it: the problem persists even if you have to zoom a little more to see the pixels.
The strange thing is that I immediately see from the press preview that will be pixelated, and I can't understand why.
I repeat that I have never changed the default cad settings and always printed the vector lines, it is only recently that I turn them into raster as output.
You know how to solve this? I still attach the settings of the pdf printer: thanks in advance
try to remove the flag from "print transparency"
and however it does not matter if the retini are saturated/transparent, they are all the lines and the vector objects to come geared
may have broken the file dwg to pdf.pc3
What version of autocad are you using?
do you have also the printers 'autocad pdf (general documentation)', 'autocad pdf (high quality print).pc3' etc.?
I eventually solved by copying everything I had in the working file into a completely new one: the lines are finally vectors. it was not a problem of autocad but of the single dwg apparently, the mysteries of autocad :d
thanks anyway to the support
