problem ad eseguire autocad 2011
  • Thread starter Thread starter djthebest93
djthebest93
as from the title I reported I have a problem in running autocad, after completing the installation is all that, finally it only touches me to get it started for the first time running it in administrator way I get a message "impossible to run autocad. the cause may be one of the following:1)the autocad version has not been installed correctly. run autocad installation again. 2)you do not have the rights necessary to perform autocad."
I address you after various solutions adopted, including repair, uninstallation of the software, run the dvd file "setup.exe" so administration from the start to start the installation has failed to combine anything to solve the problem.
I would like to submit to you some solution to solve the problem,such as operating system use windows 7 32 bits,can autocad I have got it to 32 bits for installation, meets the requirements required,but I do not know just how to solve the problem to start autocad correctly.
I thank in advance the answers I receive.
no not yet, I think to go on Saturday to ask for information on the problem from my dealer, if I can get off, meanwhile I looked around the web, but I didn't find anything, I hope the dealer can give me some explanation, but I also wait for answers here in the section in the meantime, having just started the autocad course, it would really convenient me to work so that I could exercise
good morning again, I rewrite here to tell you that I found the way to solve the problem on a site of autodesk, find a solution to solve the problem is very hard, especially to find who can give you a hand, precisely for this reason placed here the site where to go to contact the solution to solve the problem like mine, in case in the future other unfortunates meet my same problem, where to find a help is very difficulthttp://usa.autodesk.com/adsk/servlet/ps/dl/item?siteid=123112&id=15014025&linkid=9240617is in English but fortunately it is not difficult to understand in solving the problem is working, so you avoid having to chase the solution to format the operating system.
nothing but say goodbye and thank you equally. :
I also respond to the same problem and do not find where the solution is explained on the original site. can you put the precise link? I have windows 32 bit and autocad 2011 original. until last night it worked and now no more!
I would have a similar problem, I tried to install autocad 2011 on so windows 8 but it does not install me completely.
I tried to run it with compatibility for wind.vista but nothing.
Can you help me? Hello and thank you!
does it say that it is compatible with win8?! I don't think so if you don't install you have 2 alternatives:
  1. autocad updates to 2015
  2. fai un downgrade a win7
you are right, so (I wonder why I don't know) doing downgrade would be like the so passed from windows 8 to 7? is it a "declassification" of the so?
and if you install the acad2011 through the properties under the heading "run the program in windows view or w7 compatibility mode"?
Wouldn't that work anyway?
would you know how to manually remove and totally autocad, or any other program?
(I tried to use ccleaner and revo uninstaller but did not create the desired effects)
Hello and thank you!:rolleyes:
doing downgrade would be as if the so passed from windows 8 to 7? is it a "declassification" of the so?
It's not a declassification. simply use an older os
maybe you, maybe not... who can say it?! Try...
ome remove manually and totally autocad, or any other program?
What do you mean, "totally"? Don't you just uninstall it from the control panel?
not enough because many related files (with the same name, whether temporary or not) are located in the register and/or various folders, occupying space, sometimes substantial.
then because because of these files, once I reinstall the autocad, I am told that in the pc the version is already installed, not allowing me to insert the activation codes. .
yesterday I took 5 hours between understanding the problem and trying to solve it, for this reason I enrolled in this forum, hoping that someone will tell me a solution!
Thanks for your time! !
see here
[h=1]how to perform an automated uninstallation of autocad 2012 and autodesk design suite 2012 family products[/h][h=1]how to remove all autodesk products from a windows system[/h]
