problem views interrupted as a result of rotation
france92
Hello everyone, I have a problem,
when I create a break in a view (to tell us: I cut part of a drawing with interrupt lines to make sure that it fits me in the sheet in the desired scale without running out of my margins), and when I rotate this interrupted view, the fractions where the object is divided, I turn out to be blurred and not aligned anymore.
recompose the view and see how the interruption lines are opened. attention that the type of interruzine does not change to the rotation of the view, where the horizontal definition remains horizontal also subsequently; therefore probably* the size in a different way. If you change your mind and you go wrong the program limit is marginal.
* probably because without knowing how the particular is done you can only make guess (more or less like always in short)
an image would help.
