problems exporting stp file with catia v5
  • Thread starter Thread starter sir--kris
sir--kris
Hi, I did some parts in catia v5.17, and now I needed to convert them to stp files.
except in the above format, but only the catia itself opens, ie, if I try to open them with other soft gives me error!
definitely there is some sorting problem or something, I tried to vary the set parameters but nothing.
at worst there is a free converter to switch from catpart to stp?
Hello to all:finger:
hi Sir--kris, I attach my settings x stp files,I don't know if they're the best but I work almost always.
Sometimes I managed to solve the problem of exports failed by opening the stp with catia and going back to stp but not asking me why.
I hope you've been helped
I thank you... very kind... but I've been keeping them like this! And I can't understand! ♪
I've done a lot of setup tests.
now I try with a separate converter, if it does not act so !!!...bohhh
I doubt that they are the other soft ones that should read it, that they are not succeeding us!
Bye-bye
spidera but I'm really getting a doubt... I want to do a test... but you this file, do you read it?
It's a test, a stupid parallelepiped with a pocket.
but did you activate the st1 license before exporting?
sincerely I do not know exactly how to do it, cmq I made a test: that is checked st1 in " list of configurations and products available. "
And nothing yet! :confused:
then activate the license and save back to stp. then post the new file and then I could say more
I open them quietly with catia v5r20, which with solidworks
I'll open it, too. but I have to activate the license... st1
here is the file after activation of the stp license.
I still don't open it with the soft, which is freecad, I'm desperately looking for a soft free, which gives me the chance to do some cinematic analysis of the pieces I designed! I don't care about the forces, the stress and what else, I just need to check the "film chain" i.e. simulate it and see any compnetrations, plasters, relative movements of endless screws, geared on chain...ecc...ecc....what but I can't do in dmu kinematics!
I find absurd that catia does not have a module already implemented, decent to do these things!...it does not have a fundamental bond I would say...i.e. the bond "of non-compnetration!" in order to see how the cinematismos are geared one with the other!...and not that it makes me set to me the relative movement, and maybe then I see teeth that overlap and/or cmq does not allow me to simulate a chain around of the wheels
