prova demo zw3d cad
  • Thread starter Thread starter deep70
Thank you for posting the video. even if the machine was not top, I must say that the 5-axis processing is always fascinating, so if zw3d manages them optimally, then it deserves an extra star;) I also add that zw3d can repair automatically and perfectly some imported stp models with the heal command, when on the same swx fails inexorably. correct geometries with zw3d always manage to be meshate with Moldovaflow at the first attempt. Great!
Good, good consideration for yours! one of the potential that zw3d. when I have time I will show youother jobs at 5axis
If automatic repair does not work, you can attempt the manual approach. and learning is easy, just read the documents in the /pdf folder, in this case cad_advanced_modeling.pdf . I also see that there are also tutos for cam to 2,4,5 axes, milling + turning. As soon as I have time, maybe for parties, I want to try some simulations:)
2018sp2 x64, but next week I would like to try 2019 beta just for curiosity. the team zw3d says that in the last version the times of regeneration have been reduced very much, although cmq I do not have an urgent need since I work especially at the level of surface modeling on the individual parts.
you actually better, but still you can't turn the 5 axes with no one if you don't have the module
Maybe I can get a full license 30 days node locked for 2019 by one of the sw developers for the moment I am much more interested in making good masses at the table by automating 3d->2d parameters. with 3d modeling I would say that I am now at a good point, although on this cad you never end up learning.
sincerely not, because if not I would not work +.....
I repeat, I was the first to use it....so...
is a node-locked, then stuck on a specific network card. are also called "installer licenses" because they are used for demos and courses using the full version, but in all cases it is time-limited. then they are also distributed to a very small group of beta testers, and I am one of those. So quiet, you will still work for a long time, at least until retirement;)
seee alla pensione:::roflmao::roflmao::roflmao::roflmao::roflmao::roflmao::roflmao:::roflmao::
Everything is in 100 .. 102 .. 104 .. who knows that progression from linear does not become exponential :
I will learn, very interesting. Know that your remarkable experience allows you to push zw3d to an advanced level. You're strong! I have a little complained about the official zwsoft forum for some specific problems related to the management of imported geometries and the surface sweep on unconnected paths:)
be if you allow I am a technician of zw3d
no excuse .. the strong side of zw3d is just the ease of working with imported maths.if you have problems...chiedimi
but with a 27" monitor like that, don't you think that zw3d would be more aesthetically beautiful in zw2012_black style?!?!? :
