Martina Webber
Good evening to all,
I am martin a technical designer and use autocad 2017, I looked everywhere and I did not find a solution to my problem (it seems like a trivial thing but I cannot understand where to put my hands) I explain.
I have a lisp that fixing a reference point manages to update all selected blocks called "quota_altimetrica". There are no problems until I change the visibility of the block (to display the symbol of the groundwater), if I try to update the quota you do not select, as if the block was another.
the only way to solve the situation is to restore the block, update the quota and then select the desired visibility, but it is not practical.
I don't know where to slam my head, I thought I'd make two different blocks and two different lisp, but they're not fighting, i.e. I loaded one or load the other, not using them in parallel.
I attach a dwg file with the block in question and the lisp (unfortunately it is in German).View attachment Quote.dwg, View attachment Quota altimetrica.lspn.b.: the attribute in the two visibility is the same, the only difference is the presence of the lines under the quota.
