revit label with progressive numbering
Ilbianco
Good evening to all,
for a university project I find myself having to number pillars, I wanted to know if it is possible to create a label with progressive numbering, which changes automatically, or do I have to change numbers manually every time?
No, there's no such thing. revit uses the intrinsic data of the elements to generate the text of the label. If you didn't write, or who for you (maybe with a simple dynamo routine), the score values then you have nothing to label.
if you use the grids and the structural pillars, automatically revit assigns the grid coordinates as a mark (e.g. a1, a2, b1 etc...) easily labelable also these
