salome - ubuntu - imported geometry
  • Thread starter Thread starter Maxwell_87
Maxwell_87
Hello guys, this is my first post on the site, I hope to debut in beauty ^^^
In the meantime I introduce myself, I am an engineering student, who has just started using linux and fluid dynamic software:)
I am desperately looking for cad programs to use on my drunk 12.04 lts 32 bit
What version of templates do you recommend me to install?
and how can I import and meshare geometries on openfoam?
I look forward to your answer, guys
cordiality. . .
cad to use on my ubuntu 12.04 lts 32 bit
cad and linux are two words that go very little in agreement, unfortunately... .
the last, salome-meca 2013:
find it on the code-aster website, which is now down so I can't give you the link, but go on www.code-aster.org and then look.
I don't know openfoam, salome accepts iges and steps as input formats.
so there is a 2013 version for 32 bits? I didn't know! !
Thank you! If I have installation problems I will write to you here:d
cordially. . .
What is alneos? memo salome 2013 universal alneos
is a version that is not developed directly from the edf (they only make 64 bit), compiled to 32 bits from this other company called alneos. If you don't have operating system constraints, I strongly recommend 64 bits, because the 32-bit one goes into ram crisis quite quickly.
And then I have another question, what is the lgpl license?
is a substantially opensource license, except for some portion of the software contained in the package: The first is for "lesser", which is to say that this software is a little less than gpl. Don't worry about it, just use the program.
If you don't have any doubts with English, I suggest you sign up for the code-aster forum, you'll need it and it's an information mine.
I will sign up for the portal, thank you for the advice! but what do you mean by system constraints? my pc is a bit dated, it is a toshiba to200 satellite of 2007!
how can I know whether to use 64 bits or not?
almost certainly is 32-bit, however to be sure to write this command in a terminal:
Code:
uname -a
And then tell us what the system answers.
almost sicuramente e' a 32 bit.
ah, I think I've been asking something pretty obvious!! I can't use the 64 bit version in my 32 bit :p
I still have 160 giga of hard disk and 2 giga of ram!
You think I might have problems with version 32bit?
If you write what error you're dating, maybe you can help yourself, but you better write on the code-aster forum: you'll find more people who can help you.
I'm enrolling!
However, beautifully copying the instructions on the site on the terminal, the installation does not start!
I would have a question to do, but the installation of salome has system prerequisites, such as installing code_aster, or python?
cordially. . .
here is the error that appears, after decompressing the package and starting the run on the terminal, and creating the installation folder.
enter the salome install directory [default=/home/pepi/salome] : /home/pepi/salome2013
salome is in english, do you want to be in french ? [y/N] : n
installation of salome v6_6_0 in /home/pepi/salome2013/salome-meca-2013.1-lgpl ...
tail: +: numero di righe non valido
verifying archive integrity...
error in md5 checksums: d41d8cd98f00b204e9800998ecf8427e is different from b73788f3fe0ebe4bff020e1ef0cffc26
Probably the file you downloaded got corrupted. Try downloading from the top.
