Maxwell_87
done!!! and now? Can I step up the installation commands?Probably the file you downloaded got corrupted. Try downloading from the top.
Yes, install.done!!! and now? Can I step up the installation commands?![]()
I do not ask permission to install, I ask only what are the commands to install the package from the terminal, since I use recently linux and I do not know how to decompress the packages, let them go etc... and I have already lost a time catastrophe to make copy paste from the sites found on the internet and see me always popping, error, error, error...Yes, install. :
You must specify step by step where you block and what error the software signals, otherwise it is impossible to help you.I do not ask permission to install, I ask only what are the commands to install the package from the terminal, since I use recently linux and I do not know how to decompress the packages, let them go etc... and I have already lost a time catastrophe to make copy paste from the sites found on the internet and see me always popping, error, error, error...
Okay, then, that's what I do: after extracting the package content, I took the content, a file.run and dragged it directly to the terminal; This is the message that appears to me:You must specify step by step where you block and what error the software signals, otherwise it is impossible to help you.
solved, installed, launcher created on the desktop, all working, thank you however for the availability and patience (although I mi digested the battutina on asking step by step everything in real life)You must specify step by step where you block and what error the software signals, otherwise it is impossible to help you.
ah I went to reread, I apologize so much but I had read badly, instead of "by step-by-step...", I read: "...I pass to the installation commands? "solved, installed, launcher created on the desktop, all working, thank you however for the availability and patience (although I mi digested the battutina on asking step by step everything in real life)
Say hi. .
No problem :ah I went to reread, I apologize so much but I had read badly, instead of "by step-by-step...", I read: "...I pass to the installation commands? "
I'm sorry again, I didn't mean to offend you, it was just that I thought it was weird that I asked if you could leave with the installation, I hope the misconception is cleared! :redface:
even the 64..... if possible try to use and dirver owners for your skehda video instead of those open.the software goes great now, although I found in person that the 32bit version crashes, but rarely luck!
in the forum we give you some... :biggrin:I had some questions to ask you;
No, that's how it works. if necessary you must move the geometry after creating it. as I told you at the beginning of the discussion the very primitive somo modeling functions, you should definitely model on windows and then switch to salome to make mesh.I think I have blocked features, for example I can't determine the center of a circumference, in the sense that it is as if the program uses by default the origin of the Cartesian axes as a starting point, or however a well defined point for creating some geometries, and you can't do otherwise. are these the blocked features to which it alludes in the lgpl version?
code_aster is the fem solutor. Actually, salome is not born as a solid modeler, but with the goal of being a pre and post-processing platform for the anailis fem, and therefore:other question, what's the code aster for? What exactly does he do?
I only have linux on this pc :d later I will have double partition and I will do exactly so!No, that's how it works. if necessary you must move the geometry after creating it. as I told you at the beginning of the discussion the very primitive somo modeling functions, you should definitely model on windows and then switch to salome to make mesh.
Yes, I have salome-meca, in truth I had only the need to have a discreet software for modeling and to make mesh, then do the post eventually with openfoam.code_aster is the fem solutor. Actually, salome is not born as a solid modeler, but with the goal of being a pre and post-processing platform for the anailis fem, and therefore:
modeling+mesh with salome ---> problem solution with code_aster --> results analysis with salome
salome-meca (if that's what you downloaded) is the union of salome and code-aster in a unique, discreetly integrated interface.
Try to watch freecad. I never used it, so I can't tell you if it's suitable for your purposes.in truth I had only the need to have a discreet software for modeling
I'll let you know!Try to watch freecad. I never used it, so I can't tell you if it's suitable for your purposes.
http://sourceforge.net/projects/free-cad/
awk: cannot open home/user/writing/cards in which the file is contained (no such file or directory)
self extracting salome v6_6_0 installer
enter the salome install directory [default=/home/nomeutente/salome] :
after indicating in which folder to proceed to the installation the following error message appears to me!
salome is in english, do you want to be in french? [y/N] :
installation of salome v6_6_0 in /home/username/salome6.6.0/salome-meca-2013.1-lgpl ...
suit: +: invalid row number
verification archive integrity.. .
error in md5 checksums: d41d8cd98f00b204e9800998ecf8427e is different from b73788f3fe0ebe4bff020e1ef0cffc26
pepi@ubuntu:~$
the thing I don't understand is that in the home folder the destination folder I choose from, in addition to the previously used run file
What?
http://www.code-aster.org/v2/spip.php?article303Could you help me by pointing out the correct step by step procedure?
