save to standard design
france92
I wanted to ask if you could indicate the path to get to the folder within which I should save my personal design style, so as not to have to do it again every time and be able to upload it directly from options, property of the document.
Thank you, I solved, but I wanted to know, I mis expressed myself, how to save a custom design standard, which I think I understood is different from a document template, because you charge settings that you modified regarding exclusively the properties of the drawing document .slddrw.
in particular I wanted to know in which folder I should have saved the .sldstd file, that is to say that of custom design standards, as I know that there was no default I saved the file in templates, and then I added the path in options>position of the drawing files>standard, so that the program when I say uploaded to templates.
I hope I didn't screw up and get it right.
thanks to the tips
thanks to the tips
the file "design settings-to your description.sled"You can save it in a folder at your liking.
If you need to set the entry "quote/annotation preferences" as default path, in the "file placement" tab inside
system options with the above location.
there is no specific folder, because it is a file that is not loaded automatically, but voluntarily. Anyway, charge from external file and see where you're going. copy your file.options>position of design files>standard is the precourse of the teamings
after writing the message read it again, even better if another one does it; because between poorly placed punctuation and subtle subjects it was difficult to understand what you meant.
thank you for trying to interpret my message,
However, I have a further doubt, what is "quota/annotation preferences", and how does it differ from "design standards"?
