select all objects of a layer
  • Thread starter Thread starter zintonio
Thank you all for the la.
x zintonio: using ^c is equivalent to command press control c, they are used to end commands prior to what you want to use, it could happen to be found with a situation like: copy and transparent zoom, 2 levels of interruption.
x gp: the lisp, any command you write, always returns the last valued expression, unlike vba.
bye
^c at the beginning of the string, literally means ending each active command.
is equivalent to a ctrl c by keyboard or an ec.
I get it! therefore ^c^c is a double ctrl+c that implies a double termination of active command....right?
Yes, exactly.
use fae so that when you press the icon, any command is active, it is finished before launching the one associated with the icon
