set text options attributes in multi sheet schema
  • Thread starter Thread starter L.S.F.
L.S.F.
Good morning everyone is new to the blog.
I have a series of dwg files generated by an old elecamad schematic (about 70) where there are several block references where I should set in all the usual: text style, height, factor of width and inclination because, of course, they are all different now.
Is there a way to do it in a "automatic" way without going crazy and doing it for every single attribute in every single dwg file?
unfortunately they are completely fasting of visual lisp or visual basic
Thank you very much to anyone who can help me.
the magic wand as command in autocad have not inserted it. if you do not know how to develop lisp or macro I fear you touch the dear and old method "coleman"
It's the same message, how can you not be inherent?
Yes, my message is almost identical.
After rereading the other previous posts to mine in the other conversation I wondered whether it was inherent or not and I created a new discussion by adding some details to my problem.
If you're in trouble, and if I can do that, I'll run one of them.
