silicone rubber keypad
  • Thread starter Thread starter Daniele-san
Daniele-san
Hello.
have any of you ever tried to design rubber keypads with carbon contact?
if you want to know if, with an overprint, there is the possibility to have the upper surface of the contact (key) in plastic material, if yes, what type of material is usable with silicone and in what thickness ratio (s1 and s2)? I attach a figure to hope to make more clarity
thanks for the help
laws and stick to Regulation in the specific point #8
8) up - the practice of responding to messages to get them back to the top of the list (see up!) is to be considered place. a forum is not a chat, you need patience to get answers.
Maybe you should post the question on a more appropriate section.
how inherent is the automotive with the print you have to perform? to be more precise, the automotive has a specific technology or influence in the print you have to do?
you can do as many ups as you want, but if it is the wrong section, press experts who do not care about the automotive section will answer you.
the ideal would be that you would ask moderators to move the discussion in a more convenient section without opening a double
I thank you once again for your intervention, I was thinking of duplicating the discussion considering the 0 answers regarding the subject of the discussion, but it would be more right to move it from the administrator as you are recommending me
ps: I didn't put any more ups beyond the first for which you "fucked" me
I know. the meaning of the sentence is that if the section is not the most consona it does not make sense to bring it to the top of the messages.
do
Hello.
thanks for the help
You should first see if there is a polymer compatible with silicone, if yes I would say that there is no problem with a build.
Otherwise you might think of overmolding, so make sure that the silicone part covers a sufficient part of the polymer piece so that everything is soldered.
in that case will be decisive the geometry of the 2 pieces and the forces to which they are subjected
