PICO
Good morning to all, I've been following you for a long time, but it's the first time I write.
I am a designer and I have a problem that is becoming unsustainable for my work. I looked around, but apparently there's no solution, maybe I missed something... .
use autocad 2009 only in 2d to draw facades and coatings.
work only in the model space (so no layout)
in order to make "parametric" my work I need to create a tot of blocks on the prospectus drawing (we also say only 30/40 listed blocks).
In this way the same blocks can be inserted into the executive boards of each panel I have to produce and every change to the table automatically updates the prospect and vice versa.
the problem is that just created autocad blocks becomes very slow in zoom and pan and moves to snaps, despite the file is small (eg less than 1 mb).
purge and _scalelistedit are useless.
I use a portable asus m50v with cpu t9400 duo, 4 gb ram, windows view and video card nvidia 9650m gt from 1 gb.
Can there be no solution?? ? ?
