software from 3d proitions
  • Thread starter Thread starter sisaxix
If there is no news, you can also close the thread. I finally understood how the cad really function and now I will study to learn it thoroughly. Hello! :finger:
p.s. if however there is such software communicate to me!!! :biggrin:
There is.
is installed in the head of designers and designers
is called "ability to read the drawing"
is free, but it only installs with practice and experience
allows to obtain the 3d model from the various views, and it is so evolved that it also notices, in the versions "advanced" if there are inconsistencies in the views!
has a single defect, which perhaps will correct in the next releases
There is.
You forgot to say that the softwarehouses that produce these sw are called "schools"
it is not necessary and not enough:frown:
I know people who do not address these softwarehouses have a cutting edge product and others who have made various installations but do not know how to use basic functions... :mad:
They probably cpu.... You can see that they don't want to ruin it and make it run at low frequency.
Um...
If so, they would give birth to an acceptable result after a double period of time.
instead, a spider doesn't come out of a hole
or go in timeout... or there is hardware incompatibility!
try to format and re-install the s.o.?
I found a formatter that... :eek::cool:ammazza.webp
Um...
iho the problem is that ram benches are mounted which have been damaged by oxidation for poor use and goes in timeout!
